Hi,
I must have been born under a bad sign, without bad luck I'd have no luck at all. :x
The machine shop said the 78 head I just dropped off is cracked.
I was having it checked before I DIYed the port n polish. At least I didn't complete the port n polish first.
I think I'm just going to stay with my turd log, put a H/W 5200 from Stovebolt via a clifford adaptor, MSD 6 with new 78 Fairmont Dizzy and Blaster 2 coil, Clifford 6 to 2 header with divider, 2" true duals with H-pipe and DuraMax turbo mufflers. Stock cam no head work. The engine has been rebuilt by PO but I have no idea what they did with the head or if they even milled it for the gasket difference. Compression in each cylinder is around 160--checked with a cheap guage.
What's the approximate HP of this set-up? 68 block, 67 turd log head, 4 cyl T-5, 7.25 rear with 320 gears. Will I at least be able to fire 'em in first and chirp 'em in second. I want to be cool like Doug. 8)
Then I'll start saving for either AzCoupe's hinted at aluminum head or Cliffords aluminum crossflow head. By then it should be ready for a complete rebuild and I can just do the whole package at once.
Bob
Bob
