powerband 2K+ VIP Sep 12, 2005 #1 Head gasket sealant? If I use a steel shim gasket what's recommended available sealant ? (permatex #2 ? / Brylcreem?) Anybody soak or Hi-Tack composite gaskets?. How about that new cam/lifter lube? What's NAPA call it ? Thanx, Powerband 8)
wsa111 Distributor Recurving. Staff member VIP Approved Vendor Supporter 2018 Sep 12, 2005 #2 Powerband, use K & W coppercoat. Spray it on & install the gasket while its still tacky. Works great. William Do not use on composite gaskets, only steel shim gaskets.
