I just bought a used engine. The person I bought it from said that the head had been redone and had about 1000 miles on it. I have placed an additional 1000 miles on it since. I noticed a small area where my paint was fading at the head gasket just below the two center spark plugs. I wiped and repainted the area. It came back again. Is it worth trying to check or retorque the head bolts again to get the small leak to quit. If I do, should I just use the tightening sequence and check and tighten them down to 75 lbs torque. Its wierd because this seemed to happen after I replaced my leaky exhaust manifold gasket with a remflex gasket. I was all happy , it runs good and now this. I dont want to drive it anymore until I see what I can do with the problem. I am afraid that it will just get worse.
If I do this and the leak is still there should I try some Barrs stop leak. I dont want to invest a lot of money and time as I dont have a whole lot of money at the moment.
