I just took apart my 69 M head and am getting ready to take it to the machine shop. I got a few questions for all ya.
Thinking of performance here:
1 What size valves should have installed in there?
2 Should I get a 3 angle valve job?
3 Should I get the valves back-cut?
4 If the head has not been milled before, how much should I mill off to get a compression ratio of around 9.5:1-10:1?
5 What valve springs and retainers should I go with if I get the larger valves?
I hope that this will be a good build up for my car. I plan on getting the log milled to accept a holley 2 bbl. and I will be using a steel-shim head gasket. Just keep in mind my other mods so I can get the best performance with what I have:
comp 260H
D2 w/ MSD
Small dish pistons
Thank you all for all your help with my continued project...
Later,
Paul
comp 260H
D2 w/ MSD
Small dish pistons
Later,
Paul
