HELP WITH ADAPTOR
looks as tho it is 2bbl to 1bbl adapter even tho it says the opposite the 1bbl bolt holes on the long side looks like it would be under the 2bbl flange
IOWs the 1bbl bols/studs dont go thru.. but you can see that the 2bbl bolts do
either the bolts COULD possibly be drilled and placed inside the adapter, distirbing the airflow, but it then would only mount in one direction 90 degrees out of all the rest i have seen if used with the ford spacer
maybe directly to the intake which would be correct kinda
