I recently purchased an air fuel tester the Innovate LM-1.
This is a very necessary tuning tool. I highly recommened purchasing one.
The final testing on the 4412 is as follows:
68 main jet = 14.75 cruise air fuel ratio with good drivability.
The PVCR-power valve channel restriction under the power valve 6.5
needed a .010 piece of wire placed in each restrictor to get a 12.25 air fuel ratio, without the wire the air fuel was 11.5 way too rich for peak power & economy.
The accerator pump nozzle is .031 at the present time.
I hope this helps anyone using this carburetor. As you now are using it you are pig rich & not getting peak fuel miliage & especially full throttle power. My engine is smooth as glass & I improved my fuel miliage close to that of the 7448-350 CFM carb using a 59 main jet which gives 15.0 air fuel ratio cruising. William
