Thanks guys for all the replys and thoughts.
My carb is fully ajustable and I do have the Innovate WB system on my car.
I have done so many mods trying to cure this thing I have went to far with some of them and now am waiting on parts to undo, and go diff directions with some of them.
I did some booster mods that was working and taking me in the right direcction on some of the problems, but then I went to far and now my mains went from not being able to get them to start until high RPM, to being able to make them start just off idle if I want.
The problem is I cant get them to come in at the right spot at all light loads ( like 60 MPH cruize, compaired to 40 MPH cruize and lightly incressing throttle to pull a small grade).
I believe someone meantioned using the PV to get this lean spot. I have asked about this over at the Innovate forum with no awnser.
My question was, can you use the PV to richin up the mid throttle without having the mains come in? I have learned very well how to control my mains on this carb, although as I said I am waiting on some booster tools and a arangment of different boosters and feed tubes before I can deside how to set them up.
The swinging A/F problem is at WOT and I have found many ways to address it, but none with a total cure. I do believe the main problem is the intake design, and the carb being the size it is compaired to my engines needs. IT will level out throught the first gear pull, but when I shift it drops from 12.5 to 14.0 on the A/F. Then as the RPM climbs it returns to the 12.5 at about 4000 RPM and holds it until redline ( which is only about 5200). Then when I shift third it does the same thing again, drops from 12.5 to 14.0 until RPM climbs again.
I have done some testing with the emmulsion circuit and was even able to make it go the other direction on the A/F. But right now I have my main circuit so sensitive that I can raise float level just a tick to high and the mains will start feeding setting at a idle.
A new metering block, with other new stuff will be here soon and I will start over and try work this out. The engine really likes 12.8 at WOT and if I can nail it down there through the RPM the timing can be set better and the performance climbs a noticable amount when I hit the right combo of fuel & advance.
I have learned so much I hate to put the carb down and go the other direction ( EFI system) but with this inline six it may be the best bet for me. I do plan to go with a Turbo later, but I want to do with affordable setups that others could follow and not have to go spending for EFI and all the high dollar goodies that most use. I have built many turbo setups over the years and infact use to own a performance shop here local until I was dissabled and closed it. I have mostly built Big Block & 4cly turbo cars and this inline six has its own personality for sure.
For now I think I will wait until I get my carb tools and parts and try to work with what I have. One other problem it seem we found is accel pump pull over that may be causing some of the going rich at higher RPM. Although I am not sure if I would call it that, it may be that it is to lean at low RPM ( WOT) or a combonation of the two. When I was able to make it go leaner as RPM climbs I felt with the right metering and booster setup it could be fixed, but until I get my parts I am not sure. Like others have stated, when you get one part cured it effects a nother and will create another problem. I have not found the right blend to work with this yet and will soon go through a lot more testing. I have the carb in such a state now that its pretty much wacked and no tuning will help.
My next aproach will be with a set of very responsive boosters, but with delayed timing on the mains, then have the PV valve open around 8.5 or even 10.5 if I can find one. I have a felling the biggest cure is going to come from within the metering block with things like main well size and taper. JB weld and some experimenting may find a optimal setup which is something I have not tried yet. The carb becomes one big puzzle full of comprimizes when you start going this deep and the cross over effect from one circuit to the other is something hard to follow.
All thought and ideas are welcome. I have simply jumped into this head first and A*&$#^ deep. I am sure there will, or can be, many ways to approach these problems so any new direction can be something explored that may add to the learning experiance. Although my poor engine really wishes i would get this figured out, its a good think I have a backup.
Jess
