The Pertronix "Ignitor III" HEI module has built in REV Limiter. The module is able to be set from 4000 to 9000 RPM limit.
BUT - the limiter is designed for V8 not selectable like a Tachometer. Both a Tach and Rev Limiter simply count number of Plug Firings to calculate RPM.
THEN - If the Rev Limiter is set for 4K RPM LImit for the V8 plugs firing count , at what RPM will the SIX Plug Firing Count match the number of Plug Firing of the setting for V8- 4K Limit?.
pertronixbrands.com
This has been confounding me since realizing the Pertronix module has no provision for alternates to V8 like the 4/6/8 switch on a cheap Tach.'.
GM 4-Pin HEI III Performance Ignition Module with Multi-Spark & Digital Rev Limiter
Features & Benefits Our performance ignition modules are direct replacements for popular GM and Ford electronic distributors. These modules provide enhanced high RPM performance and when used with their corresponding Flame-Thrower coil, substantially increase spark plug voltage. Multiple sparks...
pertronixbrands.com
