How much power?
i was wondering how much power this motor would make?
its a 1986 alloy head 250ci
bottom end:
- Block Deburred
- Acl race series pistons 0.040"
- All bearings Acl race.
- 200ci rods, polished and shot peened
- Arp rod bolts
- Rollmaster dual timing chain and sprockets
- Crank reground -0.10, deburred + fully balanced
- rods and pistons, flywheel, and harmonic balancer balanced
- Oil ways chamfered
- Custom sump with crank scraper, increased volume, baffles, windage tray
Head:
- Combustion chambers polished + glassbeaded
- Ports blended + Glassbeaded
- New guides with bronze inserts
- 3 angle vavle job
- Heavy duty springs + collets + retainers
- Yella terra roller rockers
running about 10.7:1 comp
Cam:
Lift at lobe in .282"
ex .282"
Timing, open in. 31'
ex. 71'
closes in. 70'
ex. 29'
Duration in. 281'
ex. 280'
0.50' duration in. 210'
ex. 210'
I'll be running a 500 holley, and a redline torker manifold, with a 2.5 inch exhaust..
Are we guessing, or do you want scientific reasoning to numbers we might have?
I'm guessing around 120RWKW without too much drama.
yeah i was hoping for 150hp at the wheels, goal is 200.. i think the cam and carby are holding me back on that one.. i was just interested in people thoughts always good to have any feedback..
motors going in a xe falcon, with a t5 and 3.7 lsd.. hoping for a flat 15 at first
I've been conservative because you still need to dial in the carb and ignition, and I didn't know the driveline.
Have yourself a chat with an engine builder, and take this with him.
Basically, programs like Engine Anylsier et al will work it out if you have the head flow figures acurately defined. What follows is from my raided supply of information from the 1982 Grand Prix and 1987 SVO Falcon publicity related info, and words from its developer Dick Johnston, Mick Web, Kevin Bartlett, and other people external to the project such as ex Repco and Ford SVE engineer Bill Santocicione. Information was published from 1982 to 1990 in Street Machine, and it's specialist offshoots, Hot Sixes and Hot 302/351's. They provide benchmarks from people who have raced and blown up Ford engines for a living. :wink:
First off, you'll see Nothing. The XF head is a high swirl head designed to be electronically ignition managed to run at 8.7:1. It'll detonate like a closed chamber GT 351 on 91 octane even on 95 octane fuel.
Any canted valve Ford engine is detonation limited, and won't give you the power you seek unless you use a racing fuel with 10.7:1 C/R. All you'll suceed in doing is holeing a piston.
If you'd like to reduce the compression to 9.5:1, and run 98 octane with an additive, you might get the close to the 206 hp that is possible with a stock XF head with 490 thou lift. Your ignition needs to be tuned for mean best torque, and the total avance held back to ensure it never detonates.
Second issue is the intake. I'm not knocking the local Redline product, it serves the purpose for getting 350, 500 or 650 cfm of Holley 2-bbl on the 250. It's priced well and is a huge step up on the stock Weber ADM set-up, but its flow numbers and cylinder to cylinder efficiency are not as good as the Ultraflow. Hence an extensively reworked engine won't see 500 cfm of Holley 4412 if its lost through ports which are robbed of flow compared to a more modern, flow bench developed intake.
Thirdly. The XF head has very small intake ports, shroaded and restricted valve sizes, and you going to flat-line at about 205 hp unless you spend 2000 dollars gas-flowing the head and then going for a better quality Ultraflow 2-bbl intake and a modified Barry Grant or Demon 2-bbl with 1.75" throttles and 1.4375" venturis. The specific power on a big canted valve Ford (V8 302 or 351) with big ports and a 280 degree cam is 50 to 57 hp per litre, with perfectly flowing carb and intake giving the higher figure. This is about 205 to 235 hp on a 4.1 Liter I6. The power increases with after market Chevy Big Block style 1.8:1 rockers over the 1.73 :1 items too, because the heads cfm rate drops of above 430 thou, and there is no proportional increase in cfm, so you have to lift the valve really high to get extra power. The costs of increasing the cfm at 430 lift onwards is very high if you do it by increasing the port sizes...there is no extra metal to highe port the heads and create a preferabel D or oval port, about 35 mm is it and then you start to hit oil in the rocker cover. Thats way good modifyiers of these heads weld them up, and savagely elogate the intkae ports to get some good high lift cfm's happening. Going to more aggressive rocker helps a lot, gas flowing helps to an extent, increasing port sizes is mega expensive!
Dick Johnston in the extensive work done by the Brisbane Engine centre from 1983 to 1987 on there proposed SVO Falcon said 196 hp with 280 degree cam, bigger carb, better intake was what you could expect before.
Forthly, the exhast is wrong. Copy the stock EB XR6 item, and stop with this 2.5" drain pipe stuff the indusry forces on the unthinking I6 boys. Anyone who has driven one would be sick of I6's in half a days driving, they drone, they loose torque. Dick Johnston mentioned that a conventional exhast must provide low end torque without restriction to wide open throttle operation in an old Street Machine 1984 magazine. Copy the 1992 Tickford exhast, which is bascially an XR8 set-up modified to tee into the XR6 exhast, and just add a good aftermarket extractor/header.
Fifth. There are no apples meets apples comparisons with rod ratios except from Engine Anaylser, and internal papers on Mopar, Chevy Ford and Mini engines. The following results are determined from a 1988 Mini A-series article, a Popular Hot Rodding Mopar LA article, and a special Ford roded Chev 350 engine article. Indications are that the 6.27" rod only liberates 3% more top end power in this range of L/R. An improvement in L/R ratio from 1.5:1 to 1.61:1 is equal to 6% improvement in ratio, but less than half the percentage increase in power. You'll be very lucky to see 6 hp more.
It is valid only when a 1.5 ratio is upscaled to 1.61, and its not valid for a 302 Z28 with 6.0 inch rods verses stock 5.7" rods (L/R goes form 1.9 to 2.0, and sees no increase)
wow your've given me abit to ponder, i tryed to find a ultraflow manifold but they are like hens teath.. i was planning on a 4bbl intake and carb with a 230' cam before summernats.. do you really reckon i will need to port the head to make 200hp?
a generious dyno will see 130+ with that set up
but it will make more like 110rwkw.
ive got simerlar setup for my speedway engine and it made 110rwkw o an accurat dyno on some more popular ones made 130.
when injected 160rwkw is possible on standerd injection manifiold but it is holding you back.
Similar threads
