The British and Euro TC, TD, TE, and TF were designed around 185/70 13 tyres, only 580 mm tall. The Aussie TE and TF was re-engineered for taller tyres, up to 185/70 14'S on the S-pack rims that Gassed260 has. This is 615 mm unloaded. Ford Oz did it to improve ride and handling.The taller tyre improves ride by brideging the pot hole or rough surface, while imprving the contact area . The Euro spec TC suspension has very little suspension travel, and doesn't run taller tyres. It will ride one heck of a lot better with taller hides, though!. The tallest I've run is 618 mm in the form of the 185/82 13's on my old TD, and it rode a lot better.
My friend Rich runs 225/60 13's on his TE, and the rear wheel arch rubs with 13*7 rims. As you go to a taller:-
+1 (14x 5.5 J factory S pack),
+2 (15x6.5J Falcon XH-XG Outback, Longreach/ED-EF, or Saab 900T),
+3 (16" rims),
+4 (17" rim),
+5 (18" rim)
the
maximum width you can run drops. The best option is the one that suits you.
Do a web search on the German/South American 'Ford Taunus'. (The car the Cortina is based on) The Germans are putting
huge wheels in the confines of the TC,TD, TE and TF versions of theirs.
You may have to limit roll stiffness, chop up roller skate wheels to make suspension bushes, and experiment with 30 mm anti-roll bars to stop wheel rub, but hey, if its gotta be radical, whats a little spinal compression?
<<<<This Euro TF Cortina with a V6 runs the earlier TC spec suspension and frame. See the big 16's on it? Yummy!
For more information on the old TC based suspension system , check this.
This guy is using a set of 205 and 295's. A full chassis clip is detailed on pages 1, 2 and 3 for a British TE station wagon, which is just a TC Cortina, really.
For wheels I decided on the traditional Revolution 5 spokes in black with a diamond turned rim. 7x15 for the front, and 10x15 for the rear. Rubber is Cooper Cobra, 205/50, and 295/50. Those arches are going to have to move out a bit.
http://images.google.co.nz/imgres?i...ate.co.uk+Cortina&hl=en&lr=&ie=UTF-8&safe=off
