MercuryMarc
1973 Pinto 5200 Carb - cleaned up but not rebuilt
Clifford Adapter
Electric Choke (electrodyne)
1969 250 block
1980 Head
Duraspark 2 Distributor
Fired it up tonight- whistles in a high pitch very loudly, with and without the air cleaner assembly attached. I retightened all the carb mounting studs, adapter bolts, all the hoses, and all the clamps and the sound persists. However is seems to run OK and I have not adjusted it yet.
It's too late for me to play with it in the driveway (Hello Neighbors!) tonight.
Any suggestions about where to investigate? Seems to me to be a vacuuum leak by the sound of it. I'm thinking of spraying carb cleaner around all the fittings and listenin for a RPM increase.
Other thoughts?
Thanks!
marc in SF
63 Comet
Clifford Adapter
1969 250 block
1980 Head
Other thoughts?
Thanks!
marc in SF
63 Comet
