i told you i'd be back, quick dsII ?
nater200
i just got another six. this time it's a 170 in a 65 ranchero. will the dsII swap work on the 170? if so what are some of the things i will run into?
p.s. glad to be back.
the duraspark is too big to fit in the block, also the oil pump driveshaft will be too small, so youll have to put in a later oil pump and driveshaft.
Howdy Back:
The question is what year is your block casting?
If the block casting is a C4, or '64, a DS II will not be an easy upgrade, because of the hole size and drive shaft differences Patrick stated.
If your '65 is a later casting, either C5 or C6, the later distributor should be a direct swap-in.
Check out your block casting #. Does this 170 have hydraulic lifters or solid?
Howdy back:
A DS II swap should work fing in a C6 170 block. Only the usual stuff to consider. Like upgrading the carb to a non-SCV type.
Keep us posted on your progress.
