Not quite, Travis.  There are four bolt patterns found on the 200/250 sixes.  Small, Medium, SBF, and Big Bell.
Early engines had the "small" four bolt pattern.
Starting with the C6DE casting, there were two extra bolt holes tapped into the block to make it possible to mount the "medium" bronco/Fairlane 3.03 bell housing.  That gives it six mounting holes, but only 4 are used on any application.
The C4 and 2.77 manual bell continue to use the "small" circle;  the 3.03 style used the bigger pattern with the upper holes.  Late in the 66 model year Ford switched all 200 sixes over to the 3.03 pattern using the "medium" pattern.
In 1969 the 250 was introduced with the same SBF bellhousing pattern as the small block 302.  That was the only pattern available on that block.
In 1981, Ford introduced the E1BB "big bell" 200.  This pattern is 2/3 rd's of the small block Ford pattern.  The lower four bolts and the locating dowels are the same, as is the low starter location.  The upper two bolts are in a unique location, however.  AOD's and T5 bells can be adapted to this block by drilling two additional bellhousing holes.  Not all bells are shaped to do this, however.
The big bell and the small bell blocks ran concurrently from 1981 to 1983 depending on application.  A high mount starter is a small bell 200.
