JackFish":1hoejkj6 said:
Your vacuum readings look OK for that cam. You can expect lower vacuum with a higher performance cam.
You probably find that the mix screw doesn't do much to alter the rpms.
yup had to confirm that, it's not really faster idle but it's more of a smother idle. and the vacum is actually very good for that cam, I have a 264/74 cam and I'm getting max 15 vac, also all over the place.
I have a manual, and i've found that I get better (stronger) idle at 10* timing, my cam is advanced 4*, have you tried to get the highest vacum in gear?
I recently was playing with the idle, It was at like 1200 also but the A/C kicked it to 850, I couldn't think why, till I saw it. because I modified my gas linkage, my old kick down was hitting the firewall not letting it idle any lower, well long story short it no longer hits, found better timing at 10* compared to 14* and was able to adjust to hit 900rpm, and AC kicks it to 650-700. not only that but I also no longer hit a ping under hard acceleration. the whole engine seems happier too.
I guess the point is try lower timing, and adjust air ratio for the smothest you can get, aka stop suttering, then go back to idle screw, also make sure you time without your vacum line hooked up to the dizzy. if adding the line adds vacum/advance it's fine, due to the fact the dizzy is meant for a stock vacum pull, hence the advance.
Richard
