Hi, was member 5 years ago, sold that car. Back with another Zephyr. This one is a challenge.
Couldn't resist for $175.
It runs good until the floats sink. lol. 1946 carb has many issues and not rebuildable.
The only usable bolt-on carb at pull-a-part was a YF(A?) from a '77 Econoline/300 c.i.
I bolted it on the car yesterday and it idled fine, but had no acceleration, I'm hoping it's just a bad accel pump diaphram?
Also didn't feel any vacuum from the 3 ports? wrong base gasket?
I'm going to de-smog the engine also.(remove the EGR valve/plumbing). then sort out whats left of vacuum hoses.
Q: will it be difficult to tune the YF to operate properly on the smaller engine?
Q: YF has 3 vacuum connections= one at the base(says EGR next to it), one at mid height on driver side and one in airhorn.
Which of the lower two should I use for the distributor?
Thanks for the HELP! Bill
