I would love your opinionS on an engine I am rebuilding for my 1974 XB Futura.
The car is an M code 250 pre xflow and is missing the carb. The gearbox was missing as well but as the car is floor shifted I am fitting a T5 from an XG falcon and the 3.27 LSD from the same ute.
The engine has already been rebuilt and is bored 30 thou over with a 214@50 thou speco cam. The head has been fitted with oversized valveS and I have the factory 2V inlet manifold available to use.
The car has pacemaker extractors and a dual 2.5 inch system already fitted.
My Question for you is what carb would you recommend?
I have a rebuilt autolite 2100 1.14 dia throttle and an ADM34 from an XE falcon.
I also have a Carter BBD from a 302 XB and an WW stromberg I think from an XY or XA.
I would assume that the WW stromberg and the Carter would be very similar in terms of fuel economy and performance and the 2100 offering the best performance while the ADM would offer the best economy.
Which is the better carb, the carter bbd or ww stromberg?
I will be modifying an XE dizzy to suit the earlier engine and will run a MSD 6AL CDI module.
What would you suggest or change for this build?
I would really appreciate all the info you guys could give me.
