All Big Six Intake manifold gasket weird leak - ideas? UPDATED 1/16
Relates to all big sixes
wallen7
You could maybe try loosening up the three bolts holding the exhaust manifold to the center of intake manifold than set the them on a good flat surface to line them up before retightening them. You might also replace that center gasket while you gave it apart too. Best of luck
I always left the 3 bolts slightly loose while installing the manifolds to the head the tightened after all others were tight - also after running and getting up to temp retighten
cornfarmer
Active member
Finally got it back up and running. The new manifold fought back a little bit - had to enlarge one of the bolt holes and the clearance for the studs on the lower front side was TIGHT. Reused the washers but installed new Hillco studs and a Remflex gasket. This van is running the best it's ever run, with more pep too. Hallelujah.
Top Poster
Staff member
Supporter 2021
Supporter 2019
REDLINE 10K
Congrats on getting back running so good, and yes sir that's a really nice looking Econoline!
