Now that I have my Duraspark dialed in, it's time for the next issue.
I believe oil is running down the valve guides because when I start up my '65 Mustang 200, she blows a blue cloud and then it goes away until the next start up. In my experience with different motors, this symptom always required either new valve stem seals or in really bad cases, a valve/guide job on the head(s)+ new seals.
Upon reading this and other forums, it appears that there are different types of valve stem seals, some better than others. Which is the best? And where do you get them?
Also, I read somewhere about putting cotton rope in the cylinder and hand cranking the piston up to support the valve when removing the spring assembly. Anybody ever hear or read about that?
Once again, any advise or tips offered will be much apprecaited.
CrashBob-wannabe mechanic
