I am starting to think our engines just drain fluids all over the floor in their natural state. It is either that, or I am not able to seal anything up when I work on it.
My C4 leaks are documented in another thread, but I also have coolant leaks and PS leaks too. Well, Friday I decided to attack the coolant leak. It has been dribbling coolant for years (not much just a small desert plate sized wet spot under the water pump, but recently the pump started squealing like crazy. I picked up the new pump and got it installing in a couple of hours. The squeal is gone and it is holding temperature way better (now it never goes above 150 unless I let it sit and idle for about 15 minutes and now it still won't overheat anymore).
However, that damn leak is still there in the exact same spot. Is there something I am doing wrong?
