hello - trying to identify the two springs in my loadomatic distrbutor for my 170 manual falcon.
does anyone have any shop manuals hiding there that have descriptions of the springs - ie diameter , no coils ,length , wire diameter that would allow me to sort through my parts for the correct ones ?
a timing light shows the distributor whacking up to full advance at approx 1200rpm (engine) and consequentkly pinging
checking the springs shows they are fairly light ones - so guess in last 50 years someone has swapped them (and have put in a new Spark Control Valve (SCV) at the carb.)
an early australian workshop manual i have actually lists the springs (ie wire diameter , number of coils , length, etc )for a 144 engine - but not for the 170 engine (later engine in australia and not in the early workshop manual
i have another workshop manual which lists the part numbers ONLY for the 144 and 170 but i have no way of identifying what the aprt nubers mean -in relation to the springhs.
the springs are listed -for the 170 +manual gearbox as :
primary spring : C1DF 12192 A
secondary spring : 8EQ-12192
will try and add a scan of the pages once i am able to (cant from work..)
