I am finishing a t5 swap froma 3 speed in a 66 Mustang Coupe 200 and my lower clutch rod just barely touches the boot of the fork. I have adjusted the rod out to where it only has 2-3 threads left and is about 8" long. This is what the rod looks like. https://www.cjponyparts.com/acp-lower-clutch-rod-adjustable-289-1965-1966/p/CRL3/
I am using the z-bar linkage, original flywheel, adapternplate from modern driveline and a new clutch. I was able to get the car to go in reverse and 1st gear without a problem so everything is installed properly from what I can tell. I remember someone else had a similar problem with theirs but cannot find that post as to what they did to actually fix it. Looking for ideas on how/where to get a longer rod that will connect to the z-bar. I have looked around and very few of these actually have dimensions in the descriptions.
