godheadcustoms
I think this will work, but I don't if it would be worth all the hassle and money for negligible(?) gains. Does anyone has any data to support or refute this theory?
Here goes: The stock 200 bock has a .030 deck height, instead of milling the block to zero deck height for proper quench, stretch the rods .030. That in itself is nothing to get excited about, but if you run a tighter ring pack with 1/16", 1/16", 3/16" rings and run .160"-.180" down from the piston crown you could end up with a compression height of 1.214"-1.234" instead of the factory 1.5". Combine this with the .030" gained from the deck height and you end up with a 5.011"-5.031" rod, up from the O.E. 4.715". This now puts the rod ratio at 1.60-1.61:1 ,again, up from the O.E. 1.5:1 ratio.
Getting custom pistons made is fairly easy and relatively inexpensive, but what I see as the problem is finding con rods in close to perfect specs from another engine to keep costs realistic. I don't want to have to do this by calling Carillo! I haven't checked into any potential rods yet, wanted to gauge concsensus first. What kind of gains, emperical or theoretical, am I looking at going to a 1.6 rod ratio assuming all else equal, i.e.- a well sorted motor with 9.2ish C.R., ported head, big valves, decent exhaust, proper cam and carb for the application, etc ?
