i did my cam swap and now have very noisy valve-train, it's not making a tapping noise, it sounds kinda like a diesel at the engine, im assuming it is just the cam breaking in, i did the initial break in with the engine reved to 2000 rpm for 20 min
To adjust valve lash, be it with a hydraulic or mechanical cam, you need to have the lifter on the heel or base circle of the camshaft lobe, and there are a couple of ways to get there. The first is the exhaust opening and intake closing method (EO/IC). Starting with cylinder No. 1 (usually the head that is farthest forward on the block is No. 1, or see our handy charts) with the valve cover off, rotate the engine until the exhaust pushrod begins to move upward. This is the point at which the exhaust valve is opening (EO), meaning the piston is through with the power stroke and nearing BDC, and it's about to begin the exhaust stroke. At this point, the intake valve is closed and the lifter is on the base circle of the camshaft and can be adjusted. To adjust lash with hydraulic lifters, simply grab the pushrod and back off the rocker-arm adjusting nut until you feel lash between the pushrod and the rocker arm. Turn the rocker arm adjusting nut while rotating the pushrod until there is no more play between the pushrod and the rocker arm, then tighten the adjusting nut one half turn. That's it, you're done. To adjust the exhaust lash, turn the engine over until the exhaust valve has completed its lift cycle and the intake valve is closed about three-quarters of the way (IC). Now, the exhaust lifter is on the base circle because the piston is finishing the intake stroke and about to begin compression. Set the lash on the exhaust valve and you're done. This needs to be done for each cylinder. But there is another way.
The Companion Cylinder (or 90-degree method).With the EO/IC method,{and a V8} you must move the crank 16 times to get all the valves adjusted
Hot Lash Gone Cold {Is a subsidiary method,} a small-block with aluminum heads and a mechanical camshaft, the lash can be set 0.003-0.004 tighter than the cam card calls for. Big-blocks with aluminum heads can be 0.005, and all-aluminum blocks and heads as much as 0.010-0.012. The reason is that when the heads get hot, they expand and outgrow the pushrod and increase the lash. Once the valves are set, you can safely run the engine to operating temperature and readjust the clearances.
Read more: http://www.carcraft.com/howto/ccrp_0702 ... z31wE0WuiP
