X2 checking the oil pump drive shaft would be a good idea.
That also reminded me of one problem car years ago. A Ford was towed to my shop for repair when the guy had lost oil pressure on the freeway. He had the oil pressure problem a short time before, he had taken it in to a repair shop were they replaced the oil pump and and oil pump drive shaft, it worked for a time but then again lost oil pressure. Pulled the parts out and found that oil pump drive shaft showed signs of some wear the rounding on the hex ends on one end. The fault was from the original distributor's shaft the broached (hex) end was excessively worn, enough so that it barely drove a new oil pump shaft. Replaced with a fresh rebuilt distributor and another new oil pump shaft to fix the sloppiness in fit, and the problem was solved.
