autoxranchero
Hi,
I got a '61 Ranchero last year, it has a '68 200 in it, condition unknown. I've put a HEI distributor in it, and tuned the carb, so it runs quite well. Compression test shows between 165 and 175, except for cyl. 1 which is 155. While idling and slow test drives, the oil light doesn't come on, but if I push it a little harder, the light will flicker on the upshift, and when I push the clutch in for a down shift, it will stay on until I finish the shift. Once I'm back at the shop, it will idle fine, without turning the light on. I pulled the valve cover, and there is a lot of sludge, I also get a black puff on start up, but after that the exhaust is clean. The pistons do have oil on top when I pull the plugs.
This appears to have been a junkyard swap, I'm surprised the compression numbers are as good as they are. I've been busy working on the suspension and a t5 swap, so have only driven it about 20 miles.
Any ideas before I take things apart? I do have a mechanical oil gauge that will go in next weekend.
edited
excellent I would say you found a big part of the low oil pressure problem with the oil pick being set up so high off the bottom of the pan. It probally got bent up at sometime during its lifetime fairly comman to see oil pans with badly bent in oil sumps. Somtimes the pans get straightened out again or replaced but often the pickup tube is not. Setting at 1/4 off the bottom is real good you could go a bit lower to 3/16 or 1/8 if you wanted, as long as you kept the clean oil and the sludge out of the inside the engine. If you build a simple baffle accross the front of pan (angled down some) that will keep the oil in the sump from climbing up the front of the pan and fix low oil pressure problem on the braking, along with one at rear of the pan sump and you should be all set. It's a great looking Ranchero and with those mods your doing it should be an excellent handler too. I am a big fan of those Watts Links I think they give the best in body / chassis control I built my first one back in 1969 for use on a 41 Willys drag racer, good luck
