David mentioned in his small6 head swap sticky that while milling a head raises compression it also improves flow slightly by lowering the valves a little deeper into the chamber. This makes sense to me. My question is if this is true,(and I don't doubt it) then why would you want to mill the block to zero before milling the head? It seems to me to make more sense to mill the deck just enough to clean it up and make it flat, then mill as much as possible from the head in order to lower the valves even more. I realize this is probably just splitting hairs but these engines need all the help they can get in the breathing dept. Any thoughts?
