I REALLY LIKE Linc's idea to use an old CD. That's a really GOOD use of all of those disks AOL sends out. He's right that it would be best for you to cc your head, so you are not just poking around in the dark.
Here's a different web site to play with for figuring your compression.
http://falconperformance.sundog.net/compcalculator.asp
It'll work pretty much the same as Lincs, but most of the numbers are preset for a 200. You'll need to change the gasket thickness to anywhere from .044 to .050, depending on the headgasket you use. The .025 is good for a stock steel shim gasket (hard to find)
Also, if you use Linc compression calculator, be sure to add 7 cc to the combustion chamber to compensate for the dish in the piston (if you've got a CA smog motor add 14 cc).
I'd suggest that you got to Falcon Performance to just play with the numbers. See how the head gasket thickness changes compresson. A Victor 3910VC is .044 compressed and a Fel-Pro is .050 compressed.
Another FYI is that a mill of .010 is equal to a reduction of 2+ cc's. As you get down to only milling the "D" shape of the combustion chamber the cc reduction will be even less. Keep in mind that you need to mill off .020 just to compesate for the new-styled head gasket.
The horsepower rating on my site is basiically just for comparison as to how changes affect the engine's output.
