Hi Guys
Been working hard on the boat.. the motor will be next winter, but still trying to work out what I will do with it. The engine bay is REALLY narrow and just fits the XA 250. This limits my re power options cause most engines are allot wider. (on the inlet side)
Currently WOT is just on 3000 rpm.. which is fair moving.. I would estimate I wouldn't want more than 3500 rpm otherwise I will be into suicide speeds. ( yes I know.. sounds good!)
Spent a few minutes this morning looking at motors
Now I have been told that for best performance WOT should be half way between max torque and max HP. Interestingly that's where mine is.
Now I see my options are:
*Do a good rebuild of the non cross-flow.. but what should I do to get the grunt up. I guessing I want a sort of 'towing' cam?
*Go for XF EFI - looks the best match power wise.. lighter and no changes to engine mounts (not sure of the bolting to the Gearbox) but I guess the Injector will be too wide for the engine bay?
*Go for a late model motor that AUII LPG motor looks like perfect power and running on LPG would be awesome. But I guess nothing would fit.. would need to redo mounts , new adapter and probably too wide anyway.
I guess I have answered my own questions.. the only real option left is to rebuild the donkey. I have a spare in the garage with no lip at all. What should I do to it for max power at about 3500 RPM ( without going wider.. so no grafting on side Weber's
[/img]
