need advice/help
65fall
my throttle linkage is kick up style and my carburetor is kick down....any advice in a linkage idea or where i can get one.....i've been searching the forum cant find anything.....my carb is 32/36 weber
Check out the HW Sticky.
Stock link:
Modded link:
Set up:
I'd be tempted to use the Carter/Weber if I could sell the HW without taking a bath. However, my setup works. I'm swappining the ball stud and spring holes.
Look at my response to mysavioreigns' posting "Throttle Linkage" posted on dec 18, 2007. You can get there by searching CrashBob. I am happy to answer any questions you may have.
CrashBob, having fun with the '65 Mustang
Say BIGREDRASA - out of curiosity, why would you prefer a Carter/Weber over a Holley/Weber?
I have cores of both H/Webers and 32/36 Weber DGVs (Carter?) and need to decide which one to rebuild for my permanent carb on my Falcon (sometime next year). I've asked on a prior posting which one is preferred but go no responses or opinions. Thanks
The Carter version has the linkage reversed from the Holley, and would adapt to the stock linkage more readily.
Air cleaners are more readily available, and cheaper.
