Just installed a new transmission (C4) and a new Holley 5200 from Stovebolt on the Stovebolt adapter, plus a 6 into 1 header(still open at teh moment) on my 73 250.
Dont have the timing dialed in yet...but it cranks and idles well. When trying to accellerate from a stop there is a huge bog or stumble, enough to kill the engine when cold, then once rolling it accelerates well throuh first, but just at about the time it should make the shift to second...it starts to break up, really cut-out badly. I pulled the plugs, all are a very light gray or even white (this was at night with a drop light) and appear to have an ashy deposit on them. I suspect a lean condition, but where to look first? Float level? Jets? Fuel pump? The car was running pretty well before with the Carter RSB and stock exhaust manifold.
Any help would be appreciated.
Brad
Brad
