I've switched to the Rotella multi-weight "diesel engine" oil for all my flat tappet cam engines (all the log sixes) but was looking for a straight weight (SAE20) for a blueprinted new engine startup.
I did purchase some SAE20 Valvoline and I called Ashland / Valvoline. The "product specialist" quickly explained that all the manufacturers are reducing zinc and other anti-wear additives and "although it should be fine, if you have a concern" to use the VR series of racing oils and/or the "premium Blue" diesel engine rated oils.
She also said the reduced additives can be determined by the "SM" classification on the newer stock. I guess I won't be using the SM 20 I bought...
Powerband 8)
Powerband 8)
