8) as david indicated, it can add power, but how much, and is the effort worth the gains? those are the questions you need to ask.
1: how much?
well you have the cost of the part, and the amount of time needed to fit the part properly, and the cost of welding it in place. fitting the part is essentially labor only, but how much is your time worth to you?
2: is it worth the gain in power?
that depends, are you building a street engine, a street strip engine, or an all out race engine? if you are building an all out race engine, then yes the effort is worth the price. any advantage you can get in an all out race engine is generally worth the effort. for anything else though, i say no. the divider that is built into the exhaust manifold/header will be sufficient.
