OK folks, I got my bung welded this morning (
) and wired up my Stewart Warner A/F gauge. As expected, she's rich. From idle to cruise speed; at part throttle or wide open. Rich.
I've borrowed an image of the guage from SW so you can see where in the meter things are.
Right now (Holley 2300 500CFm w/stock 73 jets w/ the mixture screws ONLY OUT 1 full turn and a 5.5 powervalve):
Obviously, things need to be leaner accross the board. I should be targeting the lean end of STOICH right?
I have a set of 71 jets that I was planning to install along with an 8.5 PV (based on my vac readings being between 12-16). With your best guess, are the 71's going to be small enough to make that much drop?
What should my next step be? 71 Jets then retest? Other jets?
