Junk-Falcon
hay all
if you are talking about the holley/weber 5200 carb, the solenoid is for kicking up the idle speed when you turn the ac on
Philip Cook":22t49gj4 said:I used to work at Clifford's and did not say just put a brass plug in there.
Philip Cook on 6/2/03":22t49gj4 said:When I was there we had this all figured out. I guess they forgot or do not know. They, Clifford, are supposed to take the solenoids off and put in a brass "plug" on all of the Carbs. This is do to the fact that one you will not use the solenoids and two, they get in the way of the linkage.
