I found this to be interesting.
How to install a cheap oil cooler. This particular one is a Coolant to oil heat exchanger.
This should work with our sixes, since it works with a MotorCraft FL-1 filter.
http://www.therangerstation.com/OilCooler.htm
-J-R-The Ranger Station":21tarwny said:A cheap trick ........or secret....is Ford's Factory Oil Coolers that they put on all 2.3 Turbo motors. They were also found on the Police Mustang 5.0's. If you go to a junkyard and find a Turbo Coupe T-bird or Merkur XR4ti it will have a cooler on them.
