Hey guys- I am working on adding a GT35 turbo to my VI headed motor. I have been reading about turbo oiling requirements and wanted to get some wisdom on this.
Around oiling in general, I am modifying my stock pan to a "T" pan and will be adding some small baffles as I track the car occasionally. I have a small oil cooler that will also be used in my build.
My turbo is a journal bearing setup; my oil pump puts out about 15-18lbs warm at idle and goes up to ~35 lbs by 2000 rpm. Can I assume that the stock oil pump is ok for use in this application?
