parkwood60
Thought you guys might appreciate this. After 99k miles, and 600 racing miles the original 3.3/200 died a slow death. Postmortem revealed the last 3 hours or racing had been done with the #1 piston cracked right down the middle.
And so a $200 motor was purchased from the driveway of some guy who had parted out a Falcon. After dragging it home I discovered a serial number tag epoxied to the block, and a 2002 date stamp on the head, confirming my suspicion it had been rebuilt. Some fabrication was done to convert it over to Fox body use, the stock smog exhaust manifold was chopped and sealed leaving 1, 2 and 6 cylinders opened and a 4 cylinder motorcycle header was chopped up and made into a header for those ports.
Yesterday we got it running
http://www.facebook.com/photo.php?v=261856237229190
http://www.facebook.com/photo.php?v=348532678522492
Ignore the smoke, I put a bunch of oil down the intake and plug holes before trying to get it to start. But you can't ignore the fire!
Still a bit of tuning to do. Anyone know if the stock 70s Holley 1bbl uses standard Holley jets?
