All Big Six Ordered the Scorpion 1059 Roller Rockers
Relates to all big sixes
Frank
Supporter 2021
You might be right about intake manifold to valve cover clearance.
How much clearance is there normally?
I'm not sure, the EFI manifold has been off for years. As I recall, there is some space between them. Enough to do a double gasket raising of the VC, at least. I don't want to reinvent the wheel, just get the big valves and Scorpion rockers covered, properly sealed.
THE FRENCHTOWN FLYER
5K+
Supporter 2021
Supporter 2020
Supporter 2018
It may be a bit problematic trying to use two EFI gaskets. They will interfere with each other at the plastic alignment lugs and at the raised sealing beads. An older cork type gasket may be a better choice for one.
