M '55 223 has been overheating since last fall. It runs up to 230-250degrees when cruising 55-60 on the freeway. Around town it stays at 205-210, unless i have to climb a hill or grade for any distance.
Since last fall I've had the radiator rodded and tanked, and changed the thermostat out to a 180 Degree stant.
Also I've installed a new head gasket.
Could this be a vacuum advance problem? It only rises when there's a load on the engine.
