Jamie Miles
I live in the Atlanta area and commute on Peachtree Industrial blvd., Jimmy Carter Blvd. and Interstate 85 North on a daily basis with my '72 Maverick. I'm usually comeing home at about 4 P.M.
Driving through that area at 4 P.M. in mid July, 2 things are for sure. There is LOTS of stop and go traffic, and it is very, very HOT and humid (the smog dosen't help much either).
My car was running 210-230 degrees continously, no matter my driving speed. I finally tracked it down to being that my timeing had slipped. I reset the timeing to 6 degrees BTDC, and my temperature has dropped to about 190 when driving above 30 mph. The problem now lies when sitting in stop and go traffic, which about 75% of my commute is stop and go in the afternoon (it takes me over an hour to go 22 miles). My car is getting up to 230+ degrees in stop and go traffic. I am beginning to fear that it will spin a bearing or blow the head gasket getting that hot.
The only way to cool it down is to put it in neutral and hold it at a steady 2,000 rpm. It will usually drop down to about 215 when sitting still and revving it. I do not have a fan shroud, do you guys think that would help with my idle temp? Also, do you think retarding the base timeing a little more may help? When I reset the timeing this last time, my 30+ mph driving temp dropped drastically and my gas mileage went up alot also.
My engine is totally stock 250 from a 1974 Maverick Grabber, 210,000 miles (I know, alot of miles, but it still runs alright), with a Duraspark II upgrade and TFI coil. I do have a large transmission cooler which is mounted to the front of the radiator and covers about 85% of the radiator. I currently have a 180 degree thermostat in it. I replaced the 4 blade fan with a 6 blade fan from a 6 cylinder factory A/C Maverick that was in the junkyard. It seemed to help some.
Any tips to get my temp down in stop and go traffic would be great. Sorry for the long post.
