Paper project
aussie7mains
1K+
I am currently starting to plan a Ford six powered altered for drag racing here in kwinana track.
proposal is this:-
AU 4 litre base engine.
methanol fuel administered by some sort of electronicly controlled system
natural aspiration
C4 auto trans.
Around 700kg
aiming for mid 9sec ets.
Any thoughts
A7M
You will need custom pistons in the au donk to get the comp up..
Use an earlier head, Au's have larger valves but smaller ports. Its easier to fit valves than change port size..
Solid cam, custom modded rockers..
I like the idea u have.. im in a hurry right now ill post more ideas up
(Au motor has nice MASSIVE main bearings)
I like Ray Borrets old saying when the last Bathurst Group A Commodore got NASCAR spec rods.
"We went to the racers with a grocery list of parts. They focused on rod breakages at 7000 rpm plus. Power is torque times rpm. If you want more power, find more revs!. .......we went to what was basically a NASCAR beam Chevy rod to cope with 8000 rpm "
I'd look at big ports, stick with the current block, and just run rods and pistons which will hack 7500 rpm.
For me, it would be a constant supply of aftermarket alloy SBC rods of the common 6" or , if your brave, some local (Ridgecrest?) item to drum up local business.
I'd use the Subaru forged pistons, which have the 0.945" pin, and see if there is a blank which will give you an SVO pistons A3 head, 12.5:1 style dome to fit the hemi head. Its basically like setting the bump on a diesel or Hemi 426, because you need 12 to 15:1 compression, and the AU head suits the fuel better because it allows a large amount of spark lead before torching down cylinder walls. I'd stick with the 3.632" bore.
Run a wild custom cam grind, and keep the VCT system. You could run the VCT via an ABS cut-out ring, and when the slip speed exceeds 15 km/h, run an alogorithim to wipe off cam advance.
Why not do the dirty, and grab two Cal pak Holden computers, and bank fire 12 injectors off two computers? 6 in a stock EB intake runner, and 12 upstream for added fuel. Run the same kind of plenumb as Dynoed 250's, but spend more time setting up and elipsodal cover where his was cut out.Run stub stacks, and run it off a MAP sensor. I favor the slide throttle systems, but why not run two MAP sensors on each end with two throtle bodies runing two computers. Geeze, the Delco system is so easy to tune, and alcohol injection has fuel delivery problems. Most people are so slap happy with the aftermarket systems becasue they run cobnstant feed systems, and over supply there blowers. Others just use carbs. The fuel load for a 500 hp engine is well over 27 cc per second for a F1 engine. On methonal, it goes up 1.57 to what, 42 cc per second. Why not just use twelve 360 cc Magna injectors, and pickle the engine with methonal.
The cheap bit is that most people can never afford all the right stuff in V8's. In a six, there is the common Subaru piston, Chev rods can fit, and you can blow up as many 100 dollar AU blocks you can find without crying into your beer.
Mate, if you can cam, fuel, and rev it, it wont miss two extra cylinders!
If you want an adaptor for a SBF V8 pattern C10, C9, or C4 to fit your Altered, and dont mind a right hand side starter mount, call me on 643 4535 668 and leave a message. I'll add an adaptor into my business plan.
I'm getting my adaptor business sorted out here, and I'd love to offer help a bloke form Peeerth!.
Yes we had already had some thoughts allong the lines of running dual injectors of 1 or even two Delco ECUs.
as to manifolds i dont think any stocker will cut it, although i am looking into using the lower half of the dual tract type, its got 7 throttle plates which may be usufull.
pistons and rods arent an issue well use custom alloy rods (its a dragster after all) and some sort of light short forged setup.
Ive got an engine analyser programme and its telling me the header size and length and I need a cam with 260 degress @ 0.050 lift, there is no crow off the shelf, but they have lots of roller types.
the crank etc isnt a probelemm nor is the block.
A7M
Hmmm lets try 'an keep this thread move'n along! I'd LOVE to build my own li'l dragster/inliner/Altered one day/some day :lol: :P :wink: ! OO6./The-X-Or-Six!
Questions:
Why methanol? Corrosive, poisonous, hydroscopic, hard to store, hard to get.....not really that many performance advantages.
Why naturally aspirated? One good reason to run methanol is to be able to use big boost AND higher CR.
Jack The reason for methanol is because the fuel has the tremendous cooling and its quite cheap here. as to supercharging, we dont want the added complication and expense and its more of a challenge to get good performance NA
We have contemplated CNG but Ive almost ruled that out as the 4litre OHC cant get the compression high enough without compromising the combustion chamber shape.
jeff
A7M
