1961falconrat":3coszkas said:
I just want to know what the best route to take on getting dome extra performance out of would be.
What are you trying to get out of it, Daily driver, cool cruzer, full drag racer, ect?
What is the engine code? This will tell what kind of 170 you have. Do you know the history of this car? Some one may have changed the engine in the past 52 years.
If you decide to change the engine to get a better block (hydrolic lifters) consider going to a 200. I like the 170 myself but I have a more modern one, it's a sweet little motor with almost 200K (191K) on it and still running strong.
I just put a Weber Redline 32/36 DGAV 33-B-1 Carb on today.
How did you put the 32/36 on it, addapter or dirrect mount? The dirrect mount has about another 25 HP gain on a 200, should be proportional for a 170 maybe 20 HP.
What type of distributor do you have on it? If it has vacumm advance then it would make me wonder what motor is in it.
All in all you made a good start. Get it breathing and it will perform well. On the cheap with no internal engine work you can use the 32/36 and high ratio rockers 1.6 or 1.65, this is a poor mans cam upgrade, and a free flowing exhaust.
For a higher performance upgrade you can
1. Dirrect mount the carb.
2. Get a three angle valve job with some pocket porting and larger valve. These should be done on a later model head.
3. Shave the head to get a compression ratio of 9.5-1.
4. install the headers and free flowing exhaust.
5. If you rebuild the bottom end then get the crank leading edges knife edged, this should be worth 5 HP.
