Picks, 2V manifold mods 4brl in Cortina
I had some clearance issues and still do with the vac 465 4 brl I have on the way in the mail. It would have been better with a DP carby as the vac sec spring housing on a 4 brl potrudes too far towards the booster (which is already shortened 45mm). The carb in the pick is a 500 Holley just to give me some idea how the 465 would sit.
I removed a large section off the top of the manifold before welding the base plate on to keep it low and level as I also had limmited height available. I re-sealed the water jackets before welding the base on. The manifold warped "slightly"when it was welded. The 4th pick shows the manifold before it was patched up.
http://uploads.savefile.com/redir/58401.jpg
http://uploads.savefile.com/redir/58407.jpg
http://uploads.savefile.com/redir/58411.jpg
http://uploads.savefile.com/redir/58416.jpg
http://uploads.savefile.com/redir/58418.jpg
good job,great to see you doing a 2v.i realy like them,i had a 250 2v in a tc then in a te and found that a stock tf booster bracket sits back near the firewall where the others tc-te stick out alot further so i put a tf booster bracket and brake rod on my te and it worked perfect and had no clearance probs.it will pump with a 4 barrel although i shouldn't be supprised as the 250 2v stock has the most hp of all the ford pushrod sixes!
