1967 mustang with stock 200 six. Engine has only 25,000 miles on it since being rebuilt by a local speed shop that is now out of business of course.
Oil is being dumped into 2 of my cylinders. #1 and #3. Plugs foul out in those cylinders in only about 5 miles of driving. If I remove the plugs and shine a flashlight in there I can see the cylinder walls are wet with what must be oil. The others cylinders look dry and do not foul out the plugs.
I don't see any signs of of it being a head gasket. No oil in coolant or coolant in oil also amazingly the car does not smoke at all as far as I can tell.
Was hoping it was stuck oil rings and just did the Marvel Mystery oil soak where you pour MMO into each cylinder and let it soak for a couple days to free the oil rings up. All of the MMO drained past the rings and the car did not smoke at all after that either. I added 1.5 ounces to each cylinder twice, let it sit and rotated engine by hand a few times. Spent a total of 48 hours doing that whole thing. Did not help at all and brand new plugs fouled out again in those cylinders the same way.
I have previously removed the valve cover (first thing I did when this all started) and verified the valve seals look good. Now I'm thinking it may be bad valve guides. I plan to remove the valve spring on #3 and wiggle the valve stem to see if there is any play in the valve guide and go from there. Actually hoping I find something screwed up so I can get the car fixed! Don't want to pull the head and have it worked on just to later find out it is broken oil rings.
Guess I took the long way around to ask my original my question.
What valve spring compressor should I buy that will work properly on my six? Thanks!
:rolflmao: Sorry that's just a case of brain fade I guess, my valve spring compressor is made by KD and it looks kind of like this one in the below link which is probably a copy of it. Yes you can use shop air, each cylinder you want to work on needs to have the piston at TDC on the compression stroke. Or you can also go totally old school and use some clothes line rope pushed into the cylinder this works great too, its quite easy to do this job with the head on. Edited
