Plug on differential?
200ci66
I was hoping someone would be able to help me add oil to my differential. It is a 3.20 rear end from a 6 cylinder 3 speed so it would be a 7.25(?) inch rear end. I have no idea where the plug is and have looked all over the thing for it. Thanks in advance.
Look for a pipe plug near the pinon it will have a square hole in it :nod:
Use a ratchet with an extension to remove the plug. Pump axle oil into the hole until it runs out, then replace the plug.
Good to go.
