Port Divider
Here is an option for port divider instalation. after fitting make sure the divider can not move I wedged a screw driver blade where necessary. Drill a hole on each side of the divider half in the devider and half in the head tap with 1/4 20 tap and install allen head set screw bottem out and then stake the threads to lock BE CAREFUL WHEN DRILLING ! Mine came out solid as a rock
I think Jack did it that way. Personally, I like true high temp epoxy. I've used it twice, though the second head hasn't been tested yet, but the first has had no problems. Your way works great from what I hear.
Slade
