Pro Systems Racing Carburetors
Gene Fiore
This is laughable...I think. I sent an email to the tech support person at Pro Systems Carburetors to inquire if they install annular boosters on the Holley 2300 series of carbs. I have heard of this being done before with good results but not sure by whom. Anyway, this was their response:
"That is not a service we offer as we have never tested it before and it may just ruin your engine...or it may work...but its a gamble. I'd pass."
Seriously??? :shockin:
Also, according to wsa111, your holley 500-4412 can also be converted to annular discharge venturi's by Sean Murphy Induction, Just supply them the body & the installation is less the $100.00 for 2 annular boosters.
Hope this helps.
Do the mode, then grab a wide band o2 sensor, a multimeter, and then adjust the carb to ensure a lean out or over rich conditions don't kill your engine.
Some back ground.
Ford started converting 2100 2-bbls to annular discharge in 1966 for the California emmisions Mustang 289 engineds.
In 1983, the 600cfm Holley used in the 5.0 4-bbl HO engines got annular discharge venturis in the primary barrels. Result in each was a 15 cfm increase in flow in 2-bbl carbs, and 30 cfm more flow in the 4180 series carbs, up from 600 cfm to 630 cfm. This carb wasn't exclusive to the Mustang GT or Capri RS, but also found in , 5.8 and 460 HO engines in trucks up till about 1989 or so.
The 2-bbl Holley 2300 series has a vast array of versions, but basically the cfm goes up 15 to 30 cfm with annular discharge venturis. IHI and AMC versions often have a truck booster which is super restrictive, and same with the Economaster 8 leg booster found in some replacement Ford 2100 and 2150 carbs made by Holley.
As soon as the annular discharge mod happens, the main jet, idle air bleads and power valve settings are then out of calibration, and so thats why the aftermarket don't offer kits unless through some one who can make sure they aren't going to have to pay court charges for selling non approved parts for Holley carbs.
There isn't an annular discharge calibration for any 2-bbl Ford Six, but any Ford six with a 2-bbl won't have a calibration either on the Holley approved calibration list.
Gene, i have used a 4412-500 Holley with the annular discharge nozzles which were installed by Sean Murphy Induction.
They also hone out the venturi oversize to compensate for the extra restriction of the larger nozzles.
I run 67 main jets, pvcr at .053", idles restricton .031', fuel air bleed .030" & idle air bleed at .063".
I use the green accerator pump cam in the #1 position with .031 accerator pump nozzles.
The accerator pump diaphram is 30cc's & i use the green pump diaphram which is compatable with alcohol based fuels, holley # 135-10.
The metering block is made by quickfuel technologies. There are four emulsion bleeds per side.
Block the bottom bleed & the one below the top bleed. The two other bleeds are .028". this gives the best fuel curve tested with an innovate wide band A/f tester. Bill
Every engine combination could be different, but that is a good baseline to start from.
