edgewood bronco
I'm trying to save myself some cash in doing the assembly, measurement, and disassembly for this next stage. I picked up the cleaned, line-bored block and the crank today. Here's my question:
After I get the crank in and the pistons on the crank, then how do I actually measure how much deck needs to come off?
Do I throw a straight edge across and put a feeler gauge between the piston and the straight edge, or do I need a dial indicator or some such measuring device?
Also, do I need to measure every piston, or only one, or only numbers 1, 6, and, say 3?
Am I thinking correctly in that this would be a good time to plastigauge the main and rod journals?
Thanks!
Thanks!
