I've been busily welding on the Lotesque and have made substantial progress on the frame. The space frame is nearly finished with only a few more tubes to go. The biggest task ahead is brackets for front and rear suspensions.
I've even been able to mock up the steering and pedals so I can sit in it and make noises.....vroom....vroom....
I placed it on a scale. At this stage the frame weighs 123 lbs. Completed, it should tip the scale at less than 200.
200 lbs chassis
400 engine
100 tranny, clutch, and bell
100 rear end
180 wheels and tires
400 cooling system, electrical, bodywork, everything else..
1380 Total / 165 hp = 8.4 lbs/hp
That's if I build heavy. So far it's coming out to spec and could weigh as little as 1250 lbs. The 200 ci Ford should move this thing along!
200 lbs chassis
400 engine
100 rear end
:smash:
Good luck with it, it seams to be comeing along nicely.
