Recently in another thread, Deano (Execute) recommended a maximum compression ratio around 9.5:1 for a heavy usage truck engine running on propane. Having near zero personal experience with propane I did a bit of digging in the only reference book I have that shows any data; my oft-mentioned Nebraska Tractor Tests manual.
While perusing the data, I noticed that some propane models developed slightly higher HP ratings than their gasoline fueled stablemates, and some showed slightly less power. Being an inquisitive hillbilly, I tallied a few numbers (12 pages of notes) to see if there was any significant trend.
There were 55 propane powered tractors tested that had corresponding gasoline powered versions, the only differences being the obvious fuel handling/delivery equipment, and most of the propane engines had a higher compression ratio. Other than that, the engines were identical in design, bore, stroke, and rated rpm.
The earliest tractor tested was during 1949 and the latest was in 1968. Nine different manufacturers were represented with various two-cylinder, four-cylinder, and six-cylinder engines ranging between 134 cubic inches and 425 cubes. RPM varied from a low of 975 to a high speed of 2500 revs.
I added the total horsepower and divided by 55, coming up with an average output of 55.142 HP per gasoline fueled tractor.
The propane powered machines averaged 55.205 hp, an amazingly insignificant performance difference. Frankly, I had expected to see more average power on the propane tractors because of the higher average compression ratio. So much for pre-concieved notions, eh?
The Propane engines carried an average compression ratio of 8.34:1 versus the gasoline model's paltry 6.98:1 ratio, an almost 20% increase for the propane tractors.
Fuel economy PER GALLON dropped off as expected when burning propane due to the lower BTU content. An average of 9.200 Horsepoer Hours per Gallon was registered whereas the gasoline tractors showed 11. 823 HP-Hrs per Gallon for about 28% more power per gallon of gasoline than propane.
Of the 55 tractors there were nine models that also had diesel fueled versions in addition to the propane and gasoline machines. Again, these engines carried the same basic specs as the previously mentioned machines with the necessary changes to compression and fuel delivery made to accomodate the diesel fuel.
Comparing these nine tractors independantly to each other as a separate test group from the 55 in the total group showed the following results:
Propane HP- 61.55
Gasoline HP- 62.95
Diesel HP- 60.80
Propane Economy- 9.42
Gasoline Economy- 12.12
Diesel Economy- 14.30
(Economy rated in HP-Hrs per Gallon of fuel)
Even with their much higher compression ratios the Diesel models showed slightly less horsepower but significantly better economy per gallon.
There were also 5 tractors that used propane and had a diesel powered counterpart but no gasoline version. These were not included in the 55 tractors tallied above. One of these machines was interesting though, the mighty Minneapolis-Moline G-1000. This propane fired behemoth used an inline six cylinder engine sporting 4.625" bores and a stroke of 5.000" for a displacement of 504 thumpin' cubic inches! At its rated speed of 1800 rpm it cranked out 110.76 hp and 323 lbs/ft of torque with an economy rating of 9.71 hp-hrs/gal of propane. At full boogey that monster would burn almost 10.5 gallons of fuel per hour
Best have cheap fuel and a big truck to haul it!
Also among the 55 tractors were nine machines that were available as "All-Fuel" models meaning they were equipped to burn distllate or "tractor fuel". Sometimes referred to as "low-cost" fuel, it was definitely "Low-Octane" and was actually quite popular "back in the day". Visualize mixing #1 Diesel fuel with kerosene about 50-50 and that's pretty close to what distillate was with an octane rating right around 40 or so.
These nine engines averaged about 4.79:1 compression rato and while the propane/gasoline machines showed nearly identical power ratings the distillate burning tractors exhibited about 20% less horsepower per cubic inch. Again, these nine were compared as a sub-group.
Gasoline HP- 43.46
Distillate HP-34.50
Gasoline Economy- 11.90
Distillate Economy- 11.00
One tractor deserves special mention, the venerable John Deere 720. This was the only machine available in all four fuel variations. Its two-cylinder engine sported a 6" bore and a 6.375 stroke for a displacement of 360 cubic inches. At its rated speed of 1125 rpm it gave the following results:
Propane HP- 55.48
Gasoline HP-55.11
Distillate HP- 42.38
Diesel HP- 56.66
Propane Economy-9.10
Gasoline Economy-12.21
Distillate Economy- 10.89
Diesel Economy- 17.97
Propane Compression-7.94:1
Gasoline Compression- 6.14:1
Distillate Compression- 4.91:1
Diesel Compression- 16:1
The diesel version cheated slightly by using a 6.125" bore which increased displacement to 376 cubic inches, otherwise the machines were quite similar.
The JD 720 Diesel set a fuel economy record that stood from 1956 until 1983 when a Japanese built turbocharged JD Model 1650 finally edged it out for the all-time lead.
Conclusion: With the notable exception of the low-compression distillate burning tractors, it appears that similar engines burning different fuels will deliver similar power output.
Hope I didn't bore Ya'll too much,
Joe
Edit: Forgot to mention that the highest propane compression ratio was 9.8:1
Propane HP- 61.55
Gasoline HP- 62.95
Diesel HP- 60.80
Gasoline HP- 43.46
Distillate HP-34.50
Propane HP- 55.48
Gasoline HP-55.11
Diesel HP- 56.66
Joe
